Home > Maintenance & Mods (L322) > Key hole!!
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Key hole!!
Having a look at my bosses Vogue today, he has different coloured door handles and a key lock! On inspection of mine, my handles are black and no key lock?
So, how do I get in my car if my key fob fails?? Apart from using a brick!!
On a lighter note,
I've had my car for a full week without it going back to the garage Thumbs Up Thumbs Up Thumbs Up
David 2014 vogue se
Post #318726 19th Mar 2015 10:08pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
The cap on the front part of the drivers door handle pops off. Key hole underneath My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #318729 19th Mar 2015 10:11pm
chefkenmore
Now I feel like a muppet!!!
I'll stick to cooking ......................................... Thumbs Up 2014 vogue se
Post #318730 19th Mar 2015 10:14pm
Your 07 should have a normal keyhole in the drivers door. In the handle cover kit you get 4 blank covers and one keyhole cover. Whoever put the handle covers on put the 4 blank covers on (covering the drivers door lock) so... If it were me i would try to carefully remove the drivers one and make sure when you refit it you only put a small amount of double sided tape on it so if you need to remove it without tools, in the middle of a cinema carpark at midnight etc you know you can Thumbs Up
Just my 2p worth Bow down
btw, the 09> RR has a cover over the lock from factory as hoppy says above Thumbs Up
Post #318741 20th Mar 2015 12:21am
chefkenmore
That makes sense!
Thank you kind sir,
David 2014 vogue se
Post #318792 20th Mar 2015 9:21am
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I would also make sure that the key actually works the lock before you actually need to use it. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #318801 20th Mar 2015 9:57am
