Home > Off Topic > garage air compressor - advice requested |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
I think it is time for me to upgrade and replace my air compressor. I have had an Aldi compressor for 5-6 years and although it works to a point, It is getting very tired and I think it is struggling to drive my Impact gun.
14th Mar 2015 6:33pm |
Thanks, no local machine mart, but can always mail order. Electric shouldn't be a problem as I have the main box in the garage and its 2 cables and 2 meters. 200 amps I guess. Got sparky in at the moment replacing generator hook up so will get him to pop in a 20amp box for the compressor.
14th Mar 2015 8:19pm |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
Check, check and check again - before you buy!!
14th Mar 2015 9:18pm |
Think I am the unwary. just been looking at SIP catalogue and all the CFM is piston delivery so guess that will probably be what they deliver at zero pressure. Hadn't really looked at the pipe work, but 90% sure the stuff I have at the moment is 1/4bore hose.
14th Mar 2015 10:13pm |
I have a 23CFM compressor which is powerful enough to not require any air tank for storage, the only downfall is it runs on a 3 phase motor. However if you live in an older house there is a chance you have 3 phase coming into the building but it will not be connected so worth checking |
This looks like a top piece of kit that should last you forever
14th Mar 2015 10:38pm |
Don't forget that so long as the motor is dual voltage you can run a 3phase unit via an inverter which will also remove start-up load spikes. |
15th Mar 2015 7:36am |
47p2 - Screw compressor would be great, that one is in Cornwall
15th Mar 2015 8:17am |
I personally wouldn't buy SIP, they are made in the far east and in my experience cheaply made and don't last, but that's only my experience |
15th Mar 2015 9:19am |
Just to cheapen this thread I think Aldi had some 3hp twin cylinder compressors in for £169.00 last week
15th Mar 2015 9:33am |
Always good to know if there are quality issues, they claim to be made in Italy, which gave me a concern on their build quality 56 TDV8 Vogue SE
15th Mar 2015 9:36am |
My GF want to go to Aldi, so will see if they have any left and take a look, the one I currently have is an ALDI single cylinder, which has lasted 6 years, was after more air, which maybe the twin cylinder has 56 TDV8 Vogue SE
15th Mar 2015 9:39am |
Great thing about Italian stuff (or was back in the day) is that they tend to switch neutrals instead of lives. Makes live fault finding interesting If you're just needing more umph to occasionally run an impact wrench you could always simply add a larger receiver after your compressor (gas cylinder ) and then make sure you have full flow to you equipment. The compressor will get hammered trying to fill the extra storage but you only need to plug it in when required and then just use the standard unit for lower requirement jobs. Hmmm - not sure I've explained that very well I'll shut up now |
15th Mar 2015 9:50am |
