Home > In Car Electronics (L322) > Main dealer batteries? |
I fitted one of these to my TDV8. If you use the FBH it's a godsend being GEL based. It can start the car when 80% discharged and it will stand a lot of deep dishcharge cycles. Same price as LR quoting.
14th Mar 2015 1:54pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
I think varta is fitted by land rover as standard AGM was fitted post 2009 I think |
28th Mar 2015 11:32am |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 |
To a certain extent a battery is a battery. Internal components effect the lifespan, R&D contributes to safety, longevity and lifesian. Your looking at two main things the amps per hour (Ah) and the cold cranking amps (CCA). As a rule of thumb the higher the number the more power. You need high cranking amps for the FF and enough Ah to ensure it won't flatten quickly.
28th Mar 2015 12:12pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
Yes but the 110ah battery is a "difficult fit" in some tdv8s, I had to cut the bottom flange off mine which I would imagine has invalidated the warranty! There is nothing that can't be fixed with a hammer😜😜
28th Mar 2015 1:23pm |
Good point NM but do you really expect any problems? Besides fitting stuff with hammers is mandatory on most DIY projects regardless |
28th Mar 2015 1:29pm |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
I was quoted about £300 to fit a battery from dealer. I presume a 90ah one. But I sourced one for around £160. It being a varta with 110 ah. Unsure of cranking. May buy one, as the kids tv goes off after a VERY SHORT TIME after the ignition is switch off. |
29th Mar 2015 12:35am |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1200 |
I got the md battery was 171 plus vat and is the dogs, popped the bonnet struts off lifted old out and put the new in five mins job 👍
29th Mar 2015 1:43am |
I'll have another word with them to check price again. |
29th Mar 2015 3:38pm |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 |
Can't believe some of these crazy prices
29th Mar 2015 5:06pm |
