![]() | Home > Maintenance & Mods (L322) > See me home lights |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Yes it can, via dealer (at a fee). But honestly is it just another good reason to get an IID tool |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 750 ![]() ![]() ![]() |
My local Indy has " autologic" can he perform the tricks?? Would like, see me home lights, lazy locking and auto lock on pull away!!
Yes I think he should be able - other will confirm 100%
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
With mine if you pull the indicator stock towards you once the key is removed as if flashing the headlights it activates the headlights for around 30 seconds. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35528 ![]() ![]() |
as Mark says...if not then the iidtool can switch it on .. ... - .- -.
Anyone close to me got one???
iidtools are vin locked for editing ccf so unless someone has a multi vin tool then thats a no no..
Ok Stan, not like the nanocom then! I'll try Marks suggestion when I get it back from its third trip to the garage!!
Love it, thank you
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
If you purchased the IID then you could also turn on the reversing light facility to match |
Does it have anymore "hidden" secrets??????? 2014 vogue se |
loads.. |
