Home > Technical (L322) > illuminated
TerryT-J
Wales 2005 Range Rover Vogue Td6 Java Black
illuminated
I'm sure I've read it somewhere here but I've tried searching and can't find it. Basically , should the front cigarette lighter and ignition switch be illuminated at night? As an after thought, should the rear one be as well. (Ciggy lighter, not ignition switch!!) Mines a 2005 m/y. Ta, Terry.
Post #317399 10th Mar 2015 10:31pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Some had a recall from lr to fix the problems with them. I know yours is well out of the said date but are all l322 02-06 have the same cigarette lighter holder not light up?
http://www.landrover-center.com/rsm/Range-Rover-L322/15418
Mine does not light up either, even though the wires are there but the bulb holder is missing, easy fix if wanted to repair. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #317451 11th Mar 2015 10:44am
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
There are no bulb holders incorporated into the front or rear cigar lighter sockets, certainly not on our 2004 TD6. Just a +ve and -ve feed to them both, no bulb illumination wires. Same goes for the ignition switch.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #317559 11th Mar 2015 8:23pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
My se doesn't have them either which is odd _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #317611 12th Mar 2015 1:01am
