Home > Maintenance & Mods (L322) > Lose wire with plug in Engine bay?
verydisco
Hi you all,
Would you know what this loose wire is supposed to do/ where it should go? it sits on the right hand side of the engine block (passenger side)[/b]
Much thanks l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #317593 11th Mar 2015 10:21pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
looks like the connector for the changover valve on the FBH park/heat system, it sits on the bulkhead where the heater hoses enter the bulkhead
nige
Post #317613 12th Mar 2015 12:04am
verydisco
Ok, thanks. This being a Petrol V8, I must not have the FBH then.
would it be fitted on this black plastic bracket 2nd pic?
Current
Previous:
Post #317614 12th Mar 2015 12:07am
ironhorse
without looking i think it is supplied on a bracket and it fits on the threaded bolt above ,
that part just holds the extra heater pipe work in place
Post #317615 12th Mar 2015 12:24am
verydisco
thank you Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #317616 12th Mar 2015 12:49am
