Home > Maintenance & Mods (L322) > Rear door/fuel filler trap unlocking, gremlins & BCU |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 |
My Nov 2004 (2005 model with Touch-screen) Td6 is suffering from some sort of electrical gremlin which does not seem to have been talked about on this forum. The problem is intermittent: sometimes when I go to unlock the doors, the rear doors do not unlock (nor, I have subsequently, discovered, does the fuel filler trap, which is connected to the same BCU terminal, I believe). It takes several lock/unlock sequences either using the remote or the central unlock button inside the car for the rear doors to unlock. Other times there is no problem whatsoever!
8th Mar 2015 3:37pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
you should first check out the condition of the battery...make sure it holds its volts under a drop test..
8th Mar 2015 5:43pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Oi
8th Mar 2015 10:51pm |
Thanks, Stan.
9th Mar 2015 11:07am |
