Home > Technical (L322) > 4.4 V8 gearbox issue (04) |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1254 |
Yep, radiator change and gearbox oil cooler change is needed. The bottom 6 rows of the radiator had a problem where the rows collapsed, this is where the feed is taken for the gearbox oil cooler.
11th Sep 2014 11:05am |
If you have access or own a Faultmate or IID tool you can read the actual gearbox oil temperature. That will give you the best information on the actual temp the oil is running at.
11th Sep 2014 2:20pm |
Not necessarily.
@Lenb
11th Sep 2014 2:24pm |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 |
@PaulTyrer
11th Sep 2014 2:44pm |
Well took it for a test drive with tin tent on back and it happened again!!! So a new rad tomorrow (today). Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
13th Sep 2014 12:22am |
Changed the radiator and took it for yet another test (towing the tin tent) and this time all ok. Past the point where it went wrong last test and on for another 30 mins driving. Big test will come in Oct when we go down to Bournemouth - so fingers crossed.
16th Sep 2014 11:41am |
First of all, so sorry for not updating this! Didn't realise how long it had been since my last post!
5th Mar 2015 10:09am |
Whirring could be centre propshaft bearing. Worth checking if noise coming from just behind driver seat - you will need a passenger to locate source of sound.
5th Mar 2015 10:11am |
Gazellio@
5th Mar 2015 10:20am |
^ It get louder as you increase speed then stays same to ear as engine revs/road noise starts to cancel it out at speed. Pitch stays same though I think. |
5th Mar 2015 6:36pm |
Doesn't get louder & louder, clears after a few hundred yards, then doesn't return until after been stood overnight again! Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
6th Mar 2015 12:43pm |
NOT the prop bearing then. |
6th Mar 2015 12:46pm |
Gearbox? Transfer box? Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
6th Mar 2015 12:47pm |
