Home > For Sale & Wanted > [For Sale] RSE system
RSE system made for JLR by Rosen and is a dealer fit system for cars without RSE. There are two headrest screens with inbuilt DVD players/games etc. They can both play from one DVD or watch individual DVD's.
Same as here. http://www.ebay.co.uk/itm/RANGE-ROVER-VOGU...0782863669
They are Black leather (Jet) with white stiching and will fit late L322 & L405 cars.
Fitting is really quite straight forward only needing an ignition source + - Thumbs Up
They come with everything required, remote control, 2 x headsets, 2 x head rests, all wiring looms & edu/control box.
Carefully removed by me from my new car (2012my) so have had VERY little use and are in VERY good, clean - as new condition... My kids wanted a much more expensive iPad system instead hence the sale. Rolling Eyes
Priced @ £499 + P&P
Post #315428 28th Feb 2015 2:09pm
mzplcg
Craig, can I have 1st dibbs? Depends on getting the leather re-coloured cream.
PM me your number and I'll call. Might you also be able to fit ? Whistle
Post #315435 28th Feb 2015 3:18pm
PM'd Mark Thumbs Up
Post #315448 28th Feb 2015 4:46pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Craig
That's the fella I have in mine. Maybe you can help - Any idea where the control unit would be stored when dealers fit this. I'm trying to work out if I can retro fit an AUX out from the factory HU to the input on the control box so rear seat passengers can view the TV as well as the front passenger (I have the Dual TFT Screen)
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #315460 28th Feb 2015 5:58pm
Ash, if you look at the screens there are two thick cables that plug into another and eventually into the ECU/control box... Both seats plug into the ONE control box/ECU so, you should be able to follow these cables to the "hidden" control box/ECU unit Thumbs Up
Mine was under the central armrest box but, check/follow your wiring first, incase they have placed yours elsewhere Thumbs Up
Post #315466 28th Feb 2015 7:25pm
comports
cool - Thumbs Up
Do yo know if it's possible to connect into the FF HU by chance..? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #315467 28th Feb 2015 8:35pm
No idea Ash... Presumably you would need an add on box... Neutral
Share any findings with us please Ash Bow down
Post #315477 28th Feb 2015 10:02pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I have the other version of these Rosen headrests which have no actual buttons under them, just a touch sensitive panel and they certainly can connect to the dual screen tv tuner, it cost me £100 extra at the point of fitting so the actual cost of the box required must be considerably less than that.
Having said that my kids only ever watch movies or play games, they never watch the tv! 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #315490 1st Mar 2015 6:32am
comports
Thanks 160...
Did you have the system fitted aftermarket or was it there when you go the car.? Just wondering if an additional box is required or just a lead for the FF HU to the Rosen interface (Aux in)
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #315498 1st Mar 2015 8:43am
Just found these on the bay Thumbs Up
http://www.ebay.co.uk/itm/ROSEN-AV7500-PAI...233cdaaf36
Post #315523 1st Mar 2015 11:05am
mzplcg
Thanks Craig. Have sent a PM.
Post #315628 1st Mar 2015 9:09pm
Back up for sale gents Thumbs Up
Post #316258 5th Mar 2015 1:29am
Weekend pump Thumbs Up
Post #316710 7th Mar 2015 11:59am
Friday evening bump Thumbs Up
Post #317944 13th Mar 2015 10:10pm
St Pats bump Whistle
Post #318407 17th Mar 2015 10:15am
