Home > Technical (L322) > "Check coolant level" message |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8338 |
It'll be around a liter....
27th Feb 2015 10:44pm |
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 |
i did - it was colourless and no smell to it...........is that ac condensate?
27th Feb 2015 10:49pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6412 |
The drip as Haylands said is just water condensation from the A/C, nothing to worry about (usually leaves a nice pool under the car in the summer!)
27th Feb 2015 11:01pm |
exactly 240 miles since i picked it up from the mechanic after all the above mentioned work was done. Just filled up the bone dry expansion tank......2litres exactly. Cant see no other puddles except the clear condensate. |
27th Feb 2015 11:13pm |
Just keep an eye on it, they are very difficult to bleed properly and it could be air that was trapped in the system...
27th Feb 2015 11:32pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
The expansion tanks very often get pin holes in them usually along the seam that only open up at pressure leading to a steady but mysterious coolant loss . Also make sure you have the correct mixture , too much water and the SG will be wrong and throw a message I believe . 2008 MY Supercharged
28th Feb 2015 1:27am |
Cheers for the idea, but the early ones don't have that feature, mine was full of neat water when I got it and no warning was showing, cleaned my expansion bottle and it has no stains so don't think it's that... Pete
28th Feb 2015 5:55am |
Stuart Member Since: 06 Feb 2011 Location: Cambridge Posts: 85 |
Hi Haylands
28th Feb 2015 4:29pm |
