![]() | Home > Technical (L322) > 2003 Range Rover 4.4 having a mental breakdown |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8358 ![]() ![]() ![]() |
Well what your describing there is exactly what happened to mine after I took it swimming... it was under water to the depth of the boot floor, soaked loads of things as well as the BECM.... I stripped the interior out, removed the BECM, took it apart, cleaned it out with contact cleaner then left it in the airing cupboard for a week... put it all back and it worked fine...
topman1993 Member Since: 26 Feb 2015 Location: Wales Posts: 7 ![]() ![]() ![]() |
Will try this tomorrow, if this fixes it.. do you happen to know where the water is coming in from?? |
Well mine was because I parked it in the middle of a Welsh river.....
There is a plunger within the ignition switch which stops you turning the key if the immobiliser doesn't get the right signal from the BECM, you can remove it and then at least you can turn the ignition on to fault find... you can also remove the devise that locks it in park when you switch off, then you can get it on a flatbed if nothing else works.... Pete
Will check all these once the problem has been fixed! how do i go about removing the lock/ plunger?
Rather not divulge that on an open forum...
Ok, so after speaking to haylands, went out to the car to try everything he mentioned and it's decided it wanted to work today |
