Home > Technical (L322) > 02 4.4 v8 gear box problems. |
timc20xe Member Since: 05 Feb 2015 Location: Peterborough Posts: 3 |
5th Feb 2015 4:43pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35383 |
when you put the new battery on did turn the steering fully left and then fully right to set the steering parameters? ... - .- -.
5th Feb 2015 4:44pm |
Nope didn't no about that . Should I disconnect the battery then re connect and start again. ? |
5th Feb 2015 5:05pm |
as a starting point i would, details how to do this are in our wiki... ... - .- -.
5th Feb 2015 5:15pm |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 |
hi, I do not know to open a new thread, or continue here.
24th Feb 2015 12:04pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8294 |
Can't read German but I think it's telling you something about a defective solenoid in the gearbox, take it to a gearbox specialist and get them to check it...
24th Feb 2015 7:16pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
Are you able to disconnect the 16-pin electrical connector at the rear of the transmission and measure the resistance between pins 4 & 16 ?
Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
24th Feb 2015 11:25pm |
thank you all for the help and thank you Phil,
25th Feb 2015 5:00pm |
The winding resistance of the three shift solenoids (Magnetventil) should be between 26 and 30 ohms whereas the resistance of the rotary potentiometer in the transfer box shift motor is measured in kilohms. Perhaps you have the wrong scale selected on your meter?
25th Feb 2015 11:01pm |
This morning I tried to do the test again, through C1835 connector at Transmission ECU as follow image
26th Feb 2015 9:42am |
Rovertech Member Since: 25 Feb 2015 Location: Seattle Posts: 20 |
This is going to sound stupid, but bear with me. Try turning the key on (position 2) for 60-90 seconds, then off, then start the car, turn the steering wheel lock to lock.
26th Feb 2015 1:53pm |
As you’re only trying to measure 30 ohms you need to set your blue multimeter dial to ‘200’ but if you’re still getting a measurement of zero then this shows that you have found your problem i.e. a short somewhere in the solenoid circuit. As you were also measuring zero ohms at the 16-pin connector on the back of the transmission (between pins 4 & 16) this indicates that you have a problem with either the transmission wiring loom or with the solenoid itself.
26th Feb 2015 4:28pm |
Today I tried to do another electric test, before drain the transmission fluid, and remove oil pan.
3rd Mar 2015 1:26pm |
update
3rd Mar 2015 2:58pm |
