Home > Technical (L322) > Air suspention problem?
x-box
Hi Chaps
last night I turned the ignition on to check Engine oil level( the engine was not started), after about 10 minutes, I noticed some noise from the rear of the car, I think its an air suspension drop or something, after about 5 minutes, I sit inside the car, then, I felt and heard the front of the air suspension seems dropped a bit(but im not sure if its both sides of front of just one side).
after that I turned on the engine and played the air suspension up and down, seems work fine.
is there something I need to worry about and get it checked out by the dealer?
Many thanks in advance.
Best Regards
Henry.
Post #314727 25th Feb 2015 11:21am
ebajema
Sounds like some air moving around in the system. If it is working fine with running engine and no fault codes I wouldn't worry about it too much.
Or if I wanted to be rude, the system telling you to go on a diet JUST KIDDING. MY 2010 5.0 SC Galway green and sand interior!!
Post #314732 25th Feb 2015 11:38am
x-box
Bow down Bow down Bow down many thanks
and to be honest I have been on a diet since around this time last year Big Cry Big Cry Big Cry
Post #314738 25th Feb 2015 12:07pm
ebajema
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter been on a diet for decades and am glad the air suspension on FFRRs is self leveling Smile Embarassed Embarassed Embarassed MY 2010 5.0 SC Galway green and sand interior!!
Post #314740 25th Feb 2015 12:11pm
x-box
that's a good excuse to give up!!! Thumbs Up Rolling with laughter
Post #314743 25th Feb 2015 12:14pm
That is normal behavior, the system self levels after you park, if you leave the ignition on it keeps doing it for a while, mine does it all the time when working on it, just leave a door open and it should stop doing it.... Pete
Post #314745 25th Feb 2015 12:20pm
x-box
many thanks for this clarification, its good to know its a normal behaviour.
Post #314771 25th Feb 2015 2:53pm
Rovertech
United States
+1
Post #314773 25th Feb 2015 3:22pm
