Home > Maintenance & Mods (L322) > Gearbox oil change |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi markyp. When I took mine to have g/box oil & filter changed, was recommended every 20,000 mls or their about, my g/box had been changed at 70,000 mls and I had no record of there being an oil change up to when I brought it, and it had 113,000 on the clock. Made a good difference to gear changes and satisfaction I knew it had been done. |
24th Feb 2015 9:25am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Changing the gear box oil every twenty thousand miles ? it's almost cheeper to let it go bang and get a replacement . 2008 MY Supercharged
24th Feb 2015 9:43am |
really? |
24th Feb 2015 10:05am |
I was just musing , given a likely life of gear box at 150,000 miles that is at least seven oil changes in that time and lets say for ease of maths 300 pounds for an oil change that would be the price of a refurbished gearbox . There are more realistic service schedules available i'm sure . On the 6HP26 fitted to my car it would be about 70,000 miles . 2008 MY Supercharged
24th Feb 2015 11:19am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8622 |
dextron iii is cheaper than the lifeguard 6 in the 6 HP26 so the cost of swapping the fluids would be lower. Might be worth Just draining a refilling it every 30,000 miles with a filter change every 60,000. There is nothing that can't be fixed with a hammer😜😜
24th Feb 2015 6:28pm |
Cost about £130 for oil & filter change so if it prolongs the life by 20,000 mls then I'm quite happy to do that. But of course we know how our ff's can be
24th Feb 2015 7:34pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
I'm all for over servicing but I think 20,000 miles is a bit excessive, I thought ZF recommended about 80 to 100,000, so I would think 40 to 50,000 miles would be fine.....
24th Feb 2015 9:21pm |
markyp Member Since: 04 Feb 2013 Location: essex Posts: 234 |
Thanks for the replys, I rang an Indy who's local and he reckons the oil should be changed after about 25k, so it's goin in to be done in a couple of weeks, cheers, Mark 2004 vogue
25th Feb 2015 9:58pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
OP has a TD6 so it is the GM box, gearbox oil change every 20-25K would be the way I would go 56 TDV8 Vogue SE
25th Feb 2015 10:07pm |
