Home > Technical (L322) > Fuel Gauge playing up |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3808 |
I have got used to the speed of downward movement on the 5L Supercharged but this morning the gauge twice just went from 3/4 full to 1/4 full of its own accord with a corresponding drop in distance to empty of 230 miles to 89 miles.
23rd Feb 2015 1:39pm |
Rovertech Member Since: 25 Feb 2015 Location: Seattle Posts: 20 |
Typically senders on that, you can check them yourself from the out of tank connector multi plug with an ohm meter to determine which is faulty, but I always replace both. |
25th Feb 2015 2:29pm |
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 |
Whats the approx total cost to replace both senders - my gauge is just continuously erratic. |
25th Feb 2015 9:18pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Not cheap,
25th Feb 2015 9:22pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Geoff, its a well known fault and there is a TSB about it sir... Recommended (by JLR) the dealer has your car removed the tank pump plug (internally) and solders the wiring together as the wiring plug goes wrong! Even fitting a new pump will not fix the fault long term sir... Fault is because "one pump" stops reading fuel level and a mean average is then taken so will always read 1/4 full |
25th Feb 2015 11:36pm |
Craig, I take it that I will have to pay for the work or is it warranty? Geoff |
26th Feb 2015 12:05am |
Try your dealer Geoff... Unsure weather its a non cost repair sir (i would guess probably not!) |
26th Feb 2015 1:19am |
Unnecessary quote removed
26th Feb 2015 2:01pm |
Is this a DIY job, can the bridging be done externally?
3rd Mar 2015 9:12pm |
And on how many occasions have the fix worked? I have done this 20+ times and its not failed to work yet! So, please don't be so quick to dismiss something as "GARBAGE" on an open public forum when clearly the TSB is there for a reason! and has clearly worked for me several times! |
3rd Mar 2015 10:06pm |
Craig, I'm liking the possibility that I don't need to replace the senders, can it be done externally or will I have to get the tank out in which case it's probably best left to a dealer. Geoff |
3rd Mar 2015 11:11pm |
Geoff,
4th Mar 2015 9:01am |
Thanks Craig.
4th Mar 2015 9:32am |
Exactly!!!
4th Mar 2015 9:38am |
