Home > Technical (L322) > Programming L322 key
Birdbrain
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi all.
I've done a search but can't find a solution to my problem. Mines a 2008 Vogue SE bought from an independent dealer last June. They'd bought a new key which is the one I've been using. However, I went to use old key last night and it wouldn't work. I researched his to reprogramme by turning ignition on / off & holding unlock key down on fob whilst pressing lock key 3 times etc and it worked! But 1st key now doesn't work. More research and I found if you reprogramme a 2nd key within 30 secs of 1st they should both work. They don't! So I either have one or the other functioning! Any guidance appreciated.
Post #313748 19th Feb 2015 6:27pm
daveo
do both keys start the car V8 facelift Range Rover Autobiography 22" wheels.
Post #313765 19th Feb 2015 7:47pm
Birdbrain
Tried that but it always seems t obe the last key programmed is the only one that works. Sad
Post #313882 20th Feb 2015 8:57am
daveo
hi you have two problems here, the first is the sync of the keys that will open and close the doors the other is the transponder in the key.
if the key does not start the car then the other problem does not matter,
has the key ever started the car
does it make a click when you put it next to the ignition V8 facelift Range Rover Autobiography 22" wheels.
Post #313974 20th Feb 2015 8:22pm
Birdbrain
Daveo
Both keys will start the car but only one or the other will open the central locking! I can get either key to do both functions but not both keys at the same time. The last one I try programming will do both but the other one will then only start the car if that makes sense.
Post #314472 23rd Feb 2015 12:05pm
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
I just programmed both my keys using the same method yesterday on my 2007 after replacing the batteries, took several goes though
Post #314476 23rd Feb 2015 1:08pm
Birdbrain
Thanks to Daveo for taking the time to contact me privately although we never actually managed to speak.
Spoke to our local dealer this morning and the problem was that after I initialsied the first key I was putting the 2nd key in the ignition. Once I was told that the 2nd key didn't need to go in the ignition it worked 1st time. Well 3rd time! All now sorted.
Post #314736 25th Feb 2015 11:01am
