Home > For Sale & Wanted > [SOLD] Genuine Landrover RR Rear DVD system (Pictures)
TJ101
2009 Range Rover Vogue SE TDV8 Zermatt Silver
Escapee from RRS and D2 sections,, Hope this is OK Martin Rolling Eyes
Bought for a project, but never used, still in original LR box
Dvd Player - Genuine Land Rover
Part No.: VUB502160 - See more at:
http://www.rimmerbros.co.uk/Item--i-VUB502160
Believe kit is for Range Rover L322 Single roof mounted flip down screen
Complete set up, with 10CD/DVD player, all wiring,instruction, drop down screen, mounting plate, remotes and surround trim etc etc
Can get pictures if of any interest
LR fitting instructions here http://topix.landrover.jlrext.com/topix/co...upId=1666# to give you some idea
Rimmer Bros have them list at over �4250 Shocked
�750.00 Fedex for �16 UK Only
Located Somerset
Ed to add pictures ! California F1, RR TDV8 Vog SE 90 V8 Hybrid
www.wessex4x4response.org.uk
Post #300943 26th Dec 2014 11:58am
Links no good,can you post images ? .
Post #300969 26th Dec 2014 3:50pm
TJ101
Hi
Links seam to be working now ?
Will get some actual pictures tomorrow,, can any find any on the net Question California F1, RR TDV8 Vog SE 90 V8 Hybrid
Post #300985 26th Dec 2014 6:07pm
https://www.google.co.uk/search?q=VUB50216...mp;bih=837
Post #301003 26th Dec 2014 7:43pm
TJ101
Thanks Craig Thumbs Up
The kit is about 90% of those pictures etc ie Screen, plate, trim, Changer etc California F1, RR TDV8 Vog SE 90 V8 Hybrid
Post #301006 26th Dec 2014 7:51pm
TJ101
Pictures as promised to PM's
Post #301039 27th Dec 2014 8:31am
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
How much would this cost to fit?
Post #302637 4th Jan 2015 10:46am
johnboyairey
Not as much as clipping a pair of iPads on the headrests.
Post #302638 4th Jan 2015 10:50am
TJ101
No idea really,, bought for a project but never taken from the box, bar pictures
Should look better than a pair of i pads gaffer taped to the headrests Rolling with laughter California F1, RR TDV8 Vog SE 90 V8 Hybrid
Post #302719 4th Jan 2015 7:40pm
TJ101
Bump before E Blag
�550 Inc Carriage UK below the highlands etc etc California F1, RR TDV8 Vog SE 90 V8 Hybrid
Post #313284 17th Feb 2015 4:42pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Hmmmm,
I'm rather tempted at that price..........
How does the centre console plastic bit work? I'm presuming it extends the area in the roof of the car?
Post #313301 17th Feb 2015 6:09pm
TJ101
Think you are presuming correct,, just tried to google for a picture of one fitted,, I know it attaches to the metal framework in the pictures California F1, RR TDV8 Vog SE 90 V8 Hybrid
Post #313303 17th Feb 2015 6:18pm
tb10
Sorry not to PM - I've only got two posts (however, this is the third!!) Laughing
Do you know if the roof lining needs to be cut? I'm also presuming that there will be some fixing / drilling into the headlining so once fitted .....its fitted and 'stays with the vehicle'! Confused
Post #313306 17th Feb 2015 6:28pm
tb10
Yes, you do have to cut a section out of the headlining (I've just called a friend who works at a local Stealers.)
hmmmmmmmm - I wonder.....
regards
Post #313307 17th Feb 2015 6:34pm
TJ101
Hi,,
Yes, from what i remember, there is a template showing how/where to cut and trim the headlining,,
Its a fit and leave job,,,
Told it for up yo 2010 model years California F1, RR TDV8 Vog SE 90 V8 Hybrid
Post #313309 17th Feb 2015 6:35pm
