Home > Maintenance & Mods (L322) > servotronic valve....
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
how big a job is changing this..... stealer is quoting me £268 including the VAT.... part is £114 inc the vat..... is it an easy job and anything specific i would need to do it?
Post #313223 17th Feb 2015 11:51am
easy job Andy...i paid about £60 for mine but that was back in 2010..
http://www.fullfatrr.com/forum/topic6271.h...onic+valve ... - .- -.
Post #313224 17th Feb 2015 11:55am
£114? inflation set at almost 100% over the last 4 years!!!
I paid around £56 for mine in 2010
Post #313227 17th Feb 2015 12:43pm
andyleeds
Cheers guys, so basically a straight forward job if nothing has seized on?
Am guessing need some axle stands?
Post #313229 17th Feb 2015 12:59pm
safety first Thumbs Up ... - .- -.
Post #313230 17th Feb 2015 1:07pm
andyleeds
Always Stanley, will do when I am oop north at my dads as it's close to the main dealer if goosed!
Post #313240 17th Feb 2015 1:38pm
Make sure you use the correct size Torx bit when removing the bolts as they can sometimes be seized and tight to remove Thumbs Up
Post #313259 17th Feb 2015 2:45pm
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
What is the typical symptoms of an malfunction servotronic valve? L322 Vogue 2003
Post #313268 17th Feb 2015 3:44pm
^ heavy steering when slowing down , like going round a roundabout or turning a corner. .. ... - .- -.
Post #313272 17th Feb 2015 3:53pm
Starberg
Hmm i've might experienced this once... I was going on a straight and began to slow down and when i was about to turn i felt how the steering felt heavy almost like the servo disappeared.
This have never happened since then, but sometimes the steering wheel wobbles when i reach ~60 mph after a hard acceleration. I tried with 2 set of wheels so i doubt its a balance issue. Could this also be related to the servotronic valve? L322 Vogue 2003
Post #313311 17th Feb 2015 6:38pm
