Home > Maintenance & Mods (L322) > Drivers door dead locked |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16232 |
What happens when you turn the key? If not do a battery reset... |
15th Feb 2015 8:00pm |
Rob Member Since: 17 Jan 2015 Location: south Posts: 6 |
Key opens and locks door perfect nothing when you pull handle door open okey with inside handle ??????? |
15th Feb 2015 8:07pm |
In that case you have a broken cable from outside handle to latch... Happens all the time on RR so do a search in the wiki for the fitting details sir... |
15th Feb 2015 8:09pm |
Thank you I may cancel test in the morning then. Hopefully an easy fix cheers again |
15th Feb 2015 8:13pm |
Your welcome... |
15th Feb 2015 9:01pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
JEEP ? 2008 MY Supercharged
16th Feb 2015 1:59am |
