![]() | Home > Maintenance & Mods (L322) > Steam Clean Yes or No? |
Some cantons in Switzerland insist on this - fortunately not mine. People worry about electrics but it's generally ok. I wouldn't do mine unless there's some serious mess. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
As Kurt says, keep it away from electrics. Problem is the kit that is used is super powerful. I have a steam cleaner at home, tried it out on a mildy dirty/oily engine, just didn't touch it ?
You can buy degreasers and engine cleaner that should shift old residue in visible areas with some cleverly constructed nooks and crannies getter atters and a wee bit of grime time without risking damage from a steam cleaner |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Remember to keep the engine running whilst steam cleaning.... Previously..
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Don't go there........ High pressure washers put water where water normally can't get to.
Riverstick Member Since: 06 Mar 2014 Location: Cork Posts: 117 ![]() ![]() ![]() |
Low pressure(100 psi) high temperature steam(150°) is superb for cleaning engine bays. I've been doing it for over 30 years and never once had a problem. The best method is to steam off heavy oily residue. ....This will take a while as you must continually stop to see what you are cleaning amongst the clouds of steam.
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
So right !! In the good old days where the only electrics where the dizzy cap ( and you could wipe that out ) a good steaming would help you spot any oil leaks and generally make your engine like new. Now, a steam clean is like putting your laptop in the dish washer ! |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I've done my l322 v8 a couple of times with a karcher hot washer, the type with a diesel burner, I did warm up the car, switch off, leave for 10 mins, and steam it, then sprayed on some traffic film remover, agaitated a few greasy areas with a few stiff brushes and an old toothbrush etc, gave it a good steam, even from underneath too, as I had it on some. Jacks , and I was on a step ladder, (helps) , then almost immediately after I finished, I started her up and after a few revs, I closed bonnet to bake it dry, leaving it running for about 15 mins. I washed car while I was baking it, as there was all sorts of crud balls over it. I had some old auto gym engine dresser that you spray on, it's a sort of lacquer in thinners solution, that dries off to a nice shine, like it's been clear coated, this is not to everyone's taste. But it does dull down a bit, and stops some rusting etc. looks real nice. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35638 ![]() ![]() |
remember that the FF will wade through a considerable amount of water so its pretty well insulated ...as long as you dont directly pressurem wash the electrics you will be ok.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Don't do it! You run he risk of getting fine water spray into your ABS unit amongst others. I believe crud can actually help protect your bits! |
I was always told not to steam clean engine bays as it was likely to remove all the protective wax put there at build stage.
