![]() | Home > Technical (L322) > IIDTOOL Code: P1180-01 Low side fuel pressure sensor |
Smegordead Member Since: 26 Mar 2013 Location: Maidstone, Kent Posts: 27 ![]() ![]() ![]() |
So been slowly sweeping through the error codes the FF has thrown up - all been pretty minor so far but a new code appeared this week - after a little searching I can't find much that specially relates to my engine so hoping you guys can help.
First if you haven' done a service for a while get it serviced.
I still get her serviced as per the dash indicator (or timing lapsed) via the main dealer, last one was only about 5k miles ago.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8531 ![]() ![]() ![]() |
Be careful of overdosing with fuel cleaner, if you don't dilute it to the manufacturer recommendation you run the risk of "washing the bores", this is when the excess cleaner removes the film of oil on the cylinder bores and causes scuffing of the rings and piston inducing premature wear. |
To do that kind of bore washing you'd have to be using something like petrol in wuch a strong mix the engine wouldn't fire. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Nismotec Member Since: 27 Apr 2019 Location: Dorset Posts: 54 ![]() ![]() |
did anyone get to the bottom of this? ive just started getting the same code with my gap iid.......IIDTOOL Code: P1180-01 Low side fuel pressure sensor... |
https://www.rangerovers.net/threads/l322-t...rt.328496/ FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
nice one thanks ill give that a try tomorrow... did it fix your problem? |
I can't recall but in the past I've replaced
