![]() | Home > Technical (L322) > Heating is there an issuse - or is this normal |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
dont know if this will help you but just changed the thermostat on my 4.2 and the heating is spot on now back and front easy job to do |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8703 ![]() ![]() ![]() |
Possibly a build up of crud in the little vent to the left of the Manual controls. This is where the thermistor/stat is located and can have a build up of fluf on the sensor. Give it a good blow out with a can of compressed air.(available from plumbers merchants)
rr driver Member Since: 09 Dec 2013 Location: london Posts: 181 ![]() ![]() ![]() |
thanks for the info. Will try the compressed air before speaking to the local dealer again. 2011 5.0SC Santorini Black
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 ![]() ![]() |
RR Driver wonder whether have you managed to fix heating as i am facing almost the same problems and inspite of fact that i have replaced a lot of parts still remains unsolved |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
I don't know the TD6, but in my 4.4 petrol the heating became pretty ineffective, replacing the final stage resistor improved things greatly, but perhaps you have done that already. Only Range Rovers since 1988 |
Thanks. Apologies i never updated. In the end they replaced the actual complete unit as they found a fault in there. It worked fine after that- That was for the remainning time i had before it got stolen. 2011 5.0SC Santorini Black
Thanks for your feedbacks.I was suspecting that something is wrong with hevac since i have changed all sensors/valve in engine bay for high system/resistor and still have the problems.But workshop insists when car is plugged,not any fault appears. |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Sorry bad thing. What is 'whole unit'??? 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
There are possibly two valves in the engine bay one is a double valve on the nearside inner wing (or thats where it is on mine ) the other is a single valve on the bulkhead - this was the valve that was sticking on mine - I replaced the double ,which controls the temp left and right but it was the single which acts as a diverter valve which was sticking and so was giving unusual amounts of heat worth a look |
