Home > Maintenance & Mods (L322) > arnotts airbags |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8308 |
Did look at them when I replaced mine a while ago but with shipping to the UK they were far more than the original Delphi's, and they last for years, so can't see the point.... Pete
9th Feb 2015 3:07pm |
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 |
Does someone know if the Arnott bags has longer suspension travel? Is there an advantage with them if you want to raise the L322 suspension to higher levels? |
9th Feb 2015 4:34pm |
It's the shock that controls the maximum and minimum height, not the airbag.
10th Feb 2015 8:40am |
Have a good snoop around the net on the quality of the bags. On this forum it seems that the Dunlop complete struts have a bit of a failure rate with the top bearings and the Delphis don't. If you only replace the bags, that becomes less of an issue of course but still it is worth checking out what is being said about the quality of the Arnotts.
10th Feb 2015 11:34am |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 |
Hi Ebajema,
11th Feb 2015 2:42am |
Sorry for you mate, just bought two packets of double coats today. Me and the ladies in this house love 'm
11th Feb 2015 5:37am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I thought you had to use Delphi bags on a supercharged because being a different set up the Arnott's are not compatible , as for the biscuits I don't have a sweet tooth so its Arnott pizza flavoured shapes all the way for me 2008 MY Supercharged
11th Feb 2015 8:28am |
I've just heard back from the guy I bought it off and he said that he replaced the front with OEM bags,so am pleased with that.
11th Feb 2015 8:31am |
