Home > Maintenance & Mods (L322) > Mix running rich / Engine Management Light |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8330 |
Tends to happen when the monkeys at the garage move them around, short engine cycles and a bootfull of throttle will soot up the lambda and cause it to run rich until it's been driven normally for a while...... Pete
7th Feb 2015 8:09pm |
thanks Pete.
7th Feb 2015 8:19pm |
I assume that your ECUs have all been updated with the latest software ?? My 2006 (built 2005) had some issue with the EML until we replaced the fuel pump, cleaned the entire fuel system and the inlet manifold AND updated the ECU software. After that it ran without any such issues. MY 2010 5.0 SC Galway green and sand interior!!
8th Feb 2015 6:02am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Maybe PMS sir |
8th Feb 2015 10:49am |
