Home > Technical (L322) > FBH ( please don't shoot me ) |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
Yes just a bit of copper pipe with a couple of jubilee clips. Can't remembef if it was 15mm or 22mm.
6th Feb 2015 5:04pm |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Thanks |
6th Feb 2015 5:23pm |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
I found it easier to fit a loop of pipe to the pipes in the engine compartment rather than trying to fit something to the pipes where the FBH resides. Pipe size is an odd size as well. I ended up using some 16mm diameter steel tubing bent in the shape of a U. Use a couple of brake pipe flexi clamps to clamp the pipes off then you don't loose too much coolant.
6th Feb 2015 8:24pm |
Hi vaz,
7th Feb 2015 6:28pm |
Removed the loop already otherwise could have taken a picture to show you.
8th Feb 2015 12:06am |
Well finally got round to getting the FBH removed,
9th Mar 2015 3:00pm |
