Home > In Car Electronics (L322) > 2010 dual screen removal
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Guys,
Did a search but can't find anything. Is there any guides on how to remove a 2010 Dual Screen head unit anywhere..?
Thanks
Ash Ash
2016 SDV8 AB
Post #311216 6th Feb 2015 6:10pm
top dash off i think.. ... - .- -.
Post #311233 6th Feb 2015 7:25pm
comports
Thanks Stan,
Just the dash top off do you reckon... That should be a few hex bolts and off then..
(but i bet it will be more like airbags out, end caps off etc... etc...) Ash
2016 SDV8 AB
Post #311242 6th Feb 2015 8:03pm
this is for the older FF Ash but it gives you an idea,
Post #311246 6th Feb 2015 8:15pm
comports
Thanks - Did it a few times on my old FullFat so it should be fine - Just wondered if there were any gotchas I need to be aware before I start... Don't want to break my new one. Very Happy Ash
2016 SDV8 AB
Post #311249 6th Feb 2015 8:22pm
what you up to then? ... - .- -.
Post #311252 6th Feb 2015 8:27pm
comports
Just want to have a look round the back of it..I have non factory (but oem) screens fitted and want to see if I can plug them into the HU so I can play TV through them...
Very Happy Ash
2016 SDV8 AB
Post #311255 6th Feb 2015 8:37pm
ah, good luck and dont break it... Thumbs Up ... - .- -.
Post #311256 6th Feb 2015 8:43pm
Ash,
You would need to disconnect the airbag and remove the two bolts that hold the airbag support to the dashboard support frame Thumbs Up
Post #311259 6th Feb 2015 8:58pm
Also hidden torx screws under the centre air vents too Thumbs Up
Post #311260 6th Feb 2015 8:59pm
comports
Thx Craig - I'll have a root around in there carefully before I go too mad...
I hope it's a bit warmer outside tomorrow...! Ash
2016 SDV8 AB
Post #311262 6th Feb 2015 9:01pm
roy rogers
England 2010 Range Rover SE 4.4 V8 Stornoway Grey
Hi Ash/all
With regards to the removal of the dash Ive just bought a set of piano black wood trims for my new 2010 4.4 se and I believe I need to remove the top dash and end vents and radio/ infotainment centre to fit the trims attached
I've read/ looked regarding earlier dash top removals but as mentioned in you post I'm not sure the correct procedure re
Air bag and hidden torx screws could you let me know how you get on when you get the time
Kind regards to all
Paul Thumbs Up
Post #311315 7th Feb 2015 8:47am
