Home > Technical (L322) > EBV Function Fault...Code 0xBD. What is this?
Discotigger
Plugged in my new IID Tool, cleared all faults, having noted this one and it keeps coming up. Multiple resets and it still appears.
So... anyone know what this code is and what it relates to?
Over to you.. Bow down Bow down Bow down
Post #311056 5th Feb 2015 10:42pm
Weegie
"IP-Instrument Pack
0xBD EBV function fault received from ABS ECU"
Appears to be a false message which is apparently quite common. If everything is working the advice I had was to ignore it which I do and have had no problems so far.
I am told that the 0 prefixed faults are not critical. Just another FFRR quirk. Wink
HTH John
GAP iiD BT
Post #311085 6th Feb 2015 8:37am
Discotigger
Cheers Weegie, knew there would be someone with the answer. Thumbs Up Thumbs Up
Yep, everything works as should, so will not worry about this fault code. Whistle
Post #311263 6th Feb 2015 9:09pm
I asked Patrick at GAP about this one some time ago, and he said much the same as Weegie - ignore Wink .
Post #311288 6th Feb 2015 10:47pm
