Home > Maintenance & Mods (L322) > car failed NCT - irish version of MOT |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Getting the handbrake adjusted isn't a big issue, just takes a bit of time.
3rd Feb 2015 9:48pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8325 |
They are having you on... handbrake adjustment is a quick easy job, take off wheel, remove plastic plug from disc, turn disc till the hole is about 5 o'clock, stick screwdriver in hole and flick the adjuster till it pulls up better...
3rd Feb 2015 10:06pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Why did Land Rover do away with the transmission brake, never had an issue with my Landy or the 2 Classics, only had to touch the handbrake and it would put you through the windscreen
3rd Feb 2015 11:28pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Completely different parts on the FF to the D3 & RRS Miggit... Very rarely go wrong on the FF (unlike the others!) |
3rd Feb 2015 11:38pm |
Well it's good to know that the FFRR have better flicky parking brakes than the D3 and RRS, still don't know what was wrong with a lever and a button, has worked perfectly well for donkeys years. Come to think of it haven't they done away with the gear lever too? Yesterday I couldn't spell Engineer... Today I are one!
4th Feb 2015 12:07am |
stcstc31 Member Since: 01 Jul 2014 Location: dublin Posts: 209 |
oh ok thanks everyone
4th Feb 2015 7:24am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
There's probably not much wrong with the adjustment of your handbrake, the chances are the collection of dirt in the drum is probably causing the shoes / drum to slip.
4th Feb 2015 7:39am |
Garage guy just wants to pad the bill a bit MY 2010 5.0 SC Galway green and sand interior!!
4th Feb 2015 7:40am |
I haven't played with the handbrake yet, come to think of it, don't think I've used it either. But it should be fairly easy to adjust, just looked at Rave, well easy to adjust.
4th Feb 2015 10:47pm |
Its called progression sir They work soooooo much better than the old system!!! The issue with the old system was the axle articulation! The cables would move between access height and off road height so when applying the handbrake, the lower the car, the higher the lever would need to be pulled up! Little bit of homework for all the members reading this with a manual handbrake! Park on a hill. Put your car in off road height. Pull the handbrake on (not really really pulling it) but enough to hold the car whilst the gear lever is in Neutral, then lower your suspension to access height and see how many start to roll... Thats why we now have elec handbrakes! |
4th Feb 2015 10:58pm |
Yes it can be a pita to get right. Also, depending how many times yours has been yanked up? The cables could very easily be fooked by now sir! |
4th Feb 2015 11:02pm |
Oh so your saying that it's a similar botch job to the Citroen set up, only we have to put it in park to get the key out...
5th Feb 2015 12:51am |
Nothing at all wrong with a transmission brake.
5th Feb 2015 9:19am |
