Home > Technical (L322) > Intermittent heated seat |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1702 |
Hi Gang,
2nd Feb 2015 9:48pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35370 |
easiest way to check is to put a multimeter on the battery when its running, should read around 14 to 14.5 volts..
2nd Feb 2015 9:51pm |
I had it on charge the other day and (possibly stupidly) tried the FBH whilst on charge. Battery was reading 12.6 whilst on charge but when the FBH heater kicked in it slowly dropped down past 12.0. I turned it off then (as I suspect the car would not start if it was below 12) but will test it with the engine running next time to see what it reads.
2nd Feb 2015 10:08pm |
