Home > Technical (L322) > Resetting ?
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Resetting ?
Can anyone remember a thread about having to reset the FBH after so many attempts when it fails to work (I've done a search but can't seem to find it )
Or can anyone tell how we go about doing this Thumbs Up
Post #310006 2nd Feb 2015 6:02pm
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
IId tool, or alike, or webasto software.
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #310011 2nd Feb 2015 6:30pm
J evro
Thanks Thumbs Up
Wish I had this info as I've been trying different things and not had it reset so suppose it wouldn't have worked even if I had got the thing right .......oh well back to the drawing board and to find someone with a iid tool or the like ( no good me having one as I wouldn't have a clue )
Post #310026 2nd Feb 2015 7:09pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
femove fuse 59 for a couple of mins (its 59 on an early ff) in glove box 20 amp
nige
Post #310040 2nd Feb 2015 8:18pm
sasdiscos
If it's locked out the fuse pull won't work. The FBH retains it's memory.
Steve. You remind me of a young me, not much younger mind, perhaps even a little older!
Post #310042 2nd Feb 2015 8:22pm
ironhorse
new one on me
fuse pull has reset every one i have worked on, but it is a learning curve and i have been wrong before
3 non starts and they lock out ,power down resets for another 3 goes but it still remembers the last 3 faults if interrogated by diagnostics
could be the cars software locked it out then ?
cheers nige
Post #310046 2nd Feb 2015 8:36pm
sasdiscos
Well yes, I could be wrong, but with the newer discovery ones and certainly my 2010 ff the fuse pull defiantly doesn't work.
Or maybe it's just circumstance.
My discovery one wouldn't run after battery disconnect and hard reset, fuse pull etc. req iid tool to reset and force fuel purge and test run.
I suppose it depends on the problem I guess.
Post #310051 2nd Feb 2015 9:04pm
J evro
Thanks chaps, looks like I will have to take it in to be reset then Thumbs Up
Post #310305 3rd Feb 2015 7:58pm
