Home > Technical (L322) > Sloshing Water Sound Behind Dash??? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35328 |
nice result...even if the water does leak back in , at least it can now drain out and give you peaceful motoring... ... - .- -.
29th Oct 2010 6:31pm |
CyberMrT Member Since: 26 Mar 2010 Location: Stratford upon Avon UK Posts: 60 |
I'll take some more pictures to show the location and what needs removing. L322 2002 4.4 V8 LPG
30th Oct 2010 8:28am |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
Hi John , well took the decision to remove the air intake box which was more simple than expected ...........this gave plenty of room to get a drill in to drill the holes, ........i did two one either side and out poured the water ...great result. I also took the opportunity to clean in and around the air intake box which is just a bit of OCD kicking in according to the wife but made me happy........I can’t thank you enough for pursuing this issue which has become a most gratifying fix and for me at no cost as i did all the work myself today.
30th Oct 2010 7:33pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Thats not the Wiper housing.. thats the coolant chamber for the flux capacitor. If its splooshing it need to be topped up!
30th Oct 2010 8:59pm |
Ozzy Rangie Member Since: 01 Feb 2015 Location: Perth Posts: 10 |
Thanks for attaching old thread, sounds like thats it.
1st Feb 2015 11:15pm |
Hello CyberMrT
2nd Feb 2015 4:48am |
HELP
4th Feb 2015 1:37am |
Andy.b Member Since: 04 Mar 2017 Location: Uk Posts: 3 |
I have been going over this thread again trying to find the picture of where to drill the holes to drain the water , but with no luck can anyone point me in the right direction? Also this is my first time so I am not sure if I have done this correctly |
17th Nov 2019 10:50am |
For Ozzie Rangie did you find out where to drill the holes? |
24th Nov 2019 10:47am |
Anyone on where to drill these holes? |
24th Nov 2019 10:48am |
Philsarn Member Since: 15 Jun 2019 Location: Welshpool Posts: 3 |
Hi guys there is no photos now but this chap put this below so i will try it asap.
20th Feb 2020 10:58pm |
Hi all having read all of the above I took the large centre air box out and drilled two holes each side of the vent inlets but no water came out. I must have drilled in the wrong place. I want to do this before I sell her. Please can someone help? Thank you! |
2nd Mar 2020 8:26pm |
robanzac Member Since: 07 Dec 2017 Location: New Zealand Posts: 15 |
Hello Philsarn, or indeed anyone,
14th Feb 2022 6:38pm |
I think I have fixed the problem.
4th Mar 2022 4:36am |
