Home > Maintenance & Mods (L322) > Wheel alignment post strut change?
v8rich
England 2002 Range Rover HSE Td6 Bonatti Grey
I've got to change the front r/h strut due to a leaky airbag. Does the front wheel alignment need doing afterwards? thinking more of camber rather than toe in/out.
Also can the iid tool let all the air out of just one strut?
Post #309645 1st Feb 2015 12:24pm
Best to change both at the same time, due to the shock absorbers within.
I didn't have wheel alignment redone when I changed out my front struts, and didn't affect handling or tyre wear, but I guess it can't hurt to have it done, but have a four wheel alignment done, and ensure all bushes at rear are OK.
IIRC you can let all the air out of the back or the front, but not individually with IID. .
Post #309655 1st Feb 2015 1:14pm
If the bag has a hole you won't need to deflate it sir Whistle
As said above, always do them in pairs sir Thumbs Up
And finally, yes its best practice to do 4 wheel alignment afterwards to be sure its right Thumbs Up
Post #309664 1st Feb 2015 1:33pm
SteveMFr
Site Sponsor
Actually you can deflate individual corners using the test valve function - but it is better to do a "deflate all" as the suspension has no air afterwards and cannot shift anymore until you run the engine so that the compressor switches on. Depending on how you have the RR jacked up to do the work, you may not want to have the corners on the ground to self level while you are doing work under the car Shocked
And besides, you will need to do both fronts, as Joe and Craig have suggested Smile
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #309708 1st Feb 2015 3:16pm
v8rich
Thanks, looks like I'll have to dig deep then this month and get two front struts!
Post #309898 2nd Feb 2015 9:22am
PM sent sir Thumbs Up
Post #309939 2nd Feb 2015 11:30am
