![]() | Home > Technical (L322) > 11 Plate TDv8 4.4 VSE Noobie Questions |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Hi Jeff,
discowill Member Since: 07 Jan 2015 Location: Wigan Posts: 47 ![]() ![]() ![]() |
I have a 2011 FFRR AB Black and it has the lines that follow the steering and also a line at the bottom that goes from yellow to orange to red with the 4 sensors showing on it as blocks so you can tell which one is giving out the beep, don't know about the audio bit as I always turn the stereo down, I will give it a go and see, as said before the mirror dip function is controlled from the steering wheel button going into the settings menu in between the speedo and rev counter, hope this helps. |
jeffw Member Since: 18 Jan 2015 Location: Paddock Wood Posts: 60 ![]() ![]() ![]() |
Found the dipping mirror |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
I have a MY '10 VSE and on points 1 and 2 its the same as yours - antiquated isn't it |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
Reversing camera lines are fixed unless you have Vision Assist. |
Ahhhhh....OK. Thanks.
No. |
Oooops - other than mounting it in a horse box to keep an eye on things I could never really understand when and why you would ever use one - sounds like a thread starter |
I have a covered trailer for the race car and thought it would be a good idea... 2011 4.4 TDv8 Vogue SE
Valid - add it to the list on the thread I just started - good luck with the new FF |
