Home > Technical (L322) > Ignition locking
MikeT
Russia
Ignition locking
hi guys
Was wondering if anybody knew what this fault could be before I go and get a diagnostic test
Sometimes when I put the key in the ignition it doesn't turn at all as if it's locked. If I disconnect the battery for 10 or 20 seconds and try to restart its all fine again
It isn't a problem with the battery itself as it is a new battery.
it particularly happens after a short journey with lots of electrics on. Heated seats. Lights etc etc. the. When we go to restart the ignition has this fault.
could it be some fault with the immobiliser or something ?
Thanks in advance guys
2006 FFRR SC
Post #308123 26th Jan 2015 12:56pm
this might help mike,
http://www.fullfatrr.com/forum/topic22164....ion+locked ... - .- -.
Post #308128 26th Jan 2015 1:05pm
MikeT
Russia
Thanks Stan
Yes this is exactly the same issue. However it's not the battery as it's completely new. And yes by disconnecting and reconnect ting the battery it resolves the problem every time
Just wondered if anybody found the underlying issue
Post #308143 26th Jan 2015 1:28pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
I don't know if its the same problem, but it sounds similar to a problem I had.
I had to get the ignition switches replaced. Sure Ive seen something somewhere where you can clean them up
but I couldn't get to them.
Supposedly its a common problem.
Try looking at this post http://www.fullfatrr.com/forum/topic23398.html
Hope this helps.
Grant
Post #308651 28th Jan 2015 7:31am
That is classic symptoms of this problem, fix is a new steering lock, unfortunately you have to buy the entire column at several grand... various get rounds and I will be sorting a fix soon...
See this thread
http://www.fullfatrr.com/forum/topic29878.html Pete
Post #308662 28th Jan 2015 9:28am
