Android 4.2.2 from erosion, finished. My experience | |
Hi guys, I've asked a lot of questions and got a lot of help so I thought I'd post a few of the issues I've had and how I got around them,
MID - moved to the glove box, the wires do not need extending, just separating from the head unit loom.
Brake wire - this can be left as there is an option in the settings menu to turn off the need to have this on.
HSE - I have an hse model and therefore it is just a plug and play, no need to strip the interior to run cables from the boot.
Aerial - I discovered mine had been hacked around so I need to sort this, but you should just need an ISO to fara converter lead from halfords, generally around £12 but cheaper on eBay.
I still haven't got the tv working but it may be where I live, reception etc.
I will be installing a reversing camera in the next couple of weeks to aid hitching trailers etc, I may also install a couple of amps and redo all the ice.
Hex very kindly emailed me some splash screen but I haven't plugged in the usb extensions, I forgot like an idiot, but I may look at surface mounting a couple of usb female sockets on the centre console to make plugging in accessories and flash drives easier.
