Home > Maintenance & Mods (L322) > Rusty Sills... A heads up to owners of early FFRR's
Hi
Just taken the sill covers off mine to have a look at making some rock sliders.... mine has the usual rust starting on the rear wheel arch lip but it has spread to the sill as well, picture shows where the jacking point on the rear drivers side is. You can also see some damage by some idiot in the past who missed the jacking point...
The sill covers are easy to get off, six plastic plugs underneath and then just pull it away with the doors open, it has several push fit clips, the jacking points come off by prising out the central plastic pin and pulling them off, there are also several large holes in the face of the sill with rubber bungs so should be easy to rustproof the sill from the inside with just a spray can of you favorite rust preventer.
I've repaired the damage, removed all the rust and treated mine...
Sill cover fixing
Prise out the central pin on the jacking point, I used a small screwdriver, this was the front one
Your then left with this... well hopefully yours will be better...
The sill cover is so comprehensive that there was no evidence of this with it in place, I supposed you could take out the jacking point first to see if yours is OK...
Just thought I'd share and add another job to everyone's list...!!! Pete
Post #254240 13th Apr 2014 3:58pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Gonna do mine one side at a time along with the arches. Cheers for the how to on the cover removal mate. That'll save lots of snapped bits!
Post #254242 13th Apr 2014 4:12pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Are these sill trims held on purely by the plastic clips ? No bolts to un do any where ?
Post #307624 24th Jan 2015 10:31am
Imo lot to be said for giving the sills a heavy coat of black grease before refitting the plastic sill covers and then cleaning away any excess.
Post #307639 24th Jan 2015 11:48am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I had the plastic cover sills off mine last year, painted and waxoiled.
Luckily caught before any holes appeared.
I also noticed I have rust coming through the rear wheel arch, to be expected I suppose as the car is 12 years old now.
Post #307645 24th Jan 2015 12:47pm
It is a bit more tricky if you have side steps fitted Thumbs Up .
Post #307657 24th Jan 2015 1:32pm
Another good reason for not having side steps.
Post #307684 24th Jan 2015 5:15pm
