Home > Maintenance & Mods (L322) > What components should heat up and defrost when icy?
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
So we had -5 this morning, very icy, started her up and switched on heated screen (rear and front).
Took a while (3-4 minutes) and the front screen started to clear but was a little slow. The rear screen cleared faster but I noted the side windows in the boot area did not. Are these supposed to be heated also?
The driver side wing mirror took a while but did eventually start to clear but the passenger side one did not, it remained icy. Both mirrors fold in ok and adjust etc so I am wondering what other people see when it's icy on their vehicle?
Are there any fuses that could have blown that prevent these from working?
Post #307325 23rd Jan 2015 10:16am
side windows arnt heated , thats the diverse antenna's there..
on my 2008, the rear window, front window, wipers, and side mirrors heat up.. ... - .- -.
Post #307331 23rd Jan 2015 10:34am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
One morning I though the front screen wasn't working as it took a long time to defrost but on a light frost it worked fairly quick, door mirrors work fine and clear very quick to clear as does rear screen.
As for the rear side windows the wire you see is the stereo aerial yea? If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #307333 23rd Jan 2015 10:36am
Pass mirror glass is probably U.S. sir Rolling Eyes
Post #307334 23rd Jan 2015 10:36am
scwilson
oh ok that explains the side rear windows then, I saw what I thought was a heater element but as you say, it's actually an antenna, good to know.
I'll have to take a look at the passenger mirror then. Are the mirrors auto heating or only come on when the screen(s) are heating? I wonder if there is a separate fuse for the heater element of the mirrors then, as I say, all electric adjustments work on it,
Post #307335 23rd Jan 2015 10:37am
They are ignition fed at that age, so on permanently Thumbs Up
Post #307338 23rd Jan 2015 10:50am
Welshdragon
@ Craig, when did they change then? Are you saying the facelift 06> are now switch fed and not on all the time....seem to be a backward step imo. If it dont work.......burn it!
Post #307439 23rd Jan 2015 2:54pm
scwilson
Sorry for my lack of knowledge here but what does this mean?
Post #307441 23rd Jan 2015 2:58pm
Un Serviceable sir... Thumbs Up
Post #307444 23rd Jan 2015 3:08pm
No no, they have always been ignition fed Thumbs Up
Stops them misting up in cold weather when travelling
Post #307445 23rd Jan 2015 3:09pm
