Home > General > Newbie with FFRR and issues! - Updated as I go!
Stuntman
United Kingdom 2002 Range Rover HSE Td6 Zambezi Silver
I've traced the air bag pretensioner wiring and found no breaks, I've also cleaned and sprayed and connectors that I've found, I'll replace the air bag module when I install the new android head unit and extras then try to clear the fault again.
I've also sourced a set of front headlight guards which should be here tomorrow and I'll hopefully wire in the spots first thing this morning.
I just need a set of roof rails and roof bars now
I'm finding working on the FF a lot more fun than the 26 odd 110''s, 90's, 109's, 88's, 101fc's and 130's that I've had and built.
Very little needs any extra work to fit, if any!
Post #306005 18th Jan 2015 9:22am
johnboyairey
from memory, you can perhaps pull the airbag ecu connectors, and plug into new (loose) one, to test fault, before removing all console to get to the nuts holding it in. (earth it though)
my method to test if it worked and was not faulty, was to lay face down on front seat when turning ign on first time just in case it all went t!ts up, and fired any airbags!!
crude, but err-ing on survival techniques!
Post #306049 18th Jan 2015 1:21pm
Stuntman
That's really great advice!
I'll be stripping the whole lot down anyway as I may embark on a sound deadening excercise whilst I do the head unit instal 😎
Post #306141 18th Jan 2015 8:25pm
johnboyairey
well, be sure to take some pictures, as a lot of us are interested in a modern sound upgrade like the android, i i will be changing my speakers for componant type when i do my android install. -and sticking in some matting in the doors too.
Post #306240 19th Jan 2015 9:15am
