Home > Technical (L322) > reduced engine performance |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1347 |
got this ping up yesterday evening with a flashing CEL for a few seconds , car certainly was reduced in performance , couldn't pull the skin off a rice pudding.
28th Dec 2013 11:42am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Thanks for posting that TSB , for a while now I have wondering when they rectified this and although not so good for you I find my vin No is comfortably after
28th Dec 2013 12:53pm |
crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102 |
Hi folks, I'm trying to find out what the wiring configuration would be on the plug if my supercharger aux pump was still wired wrong.
24th Jan 2015 1:07pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
My SC fell in to the bracket of those with the aux coolant pump wired the wrong way around.
24th Jan 2015 11:44pm |
Mine had insulation tape......it was very obvious! 2006 4.2 SC 2019 Renault Zoe Dynamique Nav |
24th Jan 2015 11:46pm |
Ok, thanks SKOT. I have the replacement pump coming to me and due Tuesday so I will install at next opportunity and swap the wiring around. It was not that dear so not worth not doing asif the REP were to occur how popular would I be if I said I wanted to save two hundred bucks! It is going to work hard towing the 2.5 tonne van and it can get quite warm here.
25th Jan 2015 1:42am |
scotbruce Member Since: 06 Dec 2014 Location: Aberdeen Posts: 39 |
Just had restricted performance come on at the Forth Road Bridge on the way down to Edinburgh and just managed to limp into Edinburgh city centre.
1st Feb 2015 2:46pm |
Car picked up yesterday, turbo hose replaced and returned, washed, today, without charge. Good stuff
6th Feb 2015 5:41pm |
Ok Scotbruce, I see you have a TDV8. The REP warning within this thread above is unique to the S/C engine (the Supercharger coolant pump running in reverse) but clearly it can happen with a TDV8 as well.
6th Feb 2015 10:12pm |
Good morning, I did the changeout of the S/C coolant pump today. it was a of a job. I flicked the spring wire clip off the electrical connector and lost that so had to figure out an alternative for that. I had the replacement pump on hand in readiness to install but I pulled the volute cover off the old centrif pump to prove it was still wired "wrong". It was - still spinning in the opposite direction for a centrif pump. So I was glad to be sure of that not having been previously corrected - and further reinforcing the fault that previously occured being a genuine fault.
25th Feb 2015 10:28am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8283 |
Top job, glad it's sorted, that's what makes us love them, they need constant attention.... Pete
25th Feb 2015 11:31am |
gpzjamie Member Since: 11 Aug 2013 Location: newcastle upon tyne Posts: 14 |
Hi Guys, i realise that this is an old post, but, i have just had to replace my pump due to Land Rovers error, i lost power went onto reduced performance mode , so had it checked out, my Range is 2006 offs, how many times have land rover had the oppertunity to repair this in the cars life ?? it should have been a recall, or at least a service bulletin for the 4.2 supercharged. well, thats me 300 quid out of pocket........ jamie |
14th Jul 2015 6:06pm |
jeep948 Member Since: 12 Aug 2013 Location: Scottish Borders Posts: 5 |
I have the same issue and my new pump arrived today, Sunday is the day for fitting. Has anyone got the 'Procedure for replacing the supercharger coolant pump can be found in Global Technical Reference (GTR) under section 303-03D – Supercharger Cooling. Repair Time 26.50.26 – Auxiliary coolant pump (AJV8 supercharged) – renew – 0.80hrs'.
31st Jul 2015 10:33pm |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 |
also looking for this. thanks |
12th Aug 2015 12:31pm |
