![]() | Home > Wheels & Tyres > Michelin Latitude Sport 3 275/45 R20 110 Y XL |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
As good a Michelin is I'd never recommend running a rolling radius outside of OEM specs
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Very happy with my Michelin, though they were Diamaris, when I had them on my previous L322, maybe because they are in fact a bit narrow for 255s, so are less noisy than other 255/50s
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8721 ![]() ![]() ![]() |
+1 for the latitude diamaris in 255/50 r20 109. Very good wear and quite quiet. 275/45 is the wrong size for the ff. Stick with the original spec and you will be ok.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
not far off the same rolling radius,
OK Stan would you run this size |
i would with wider RRS rims, as i have run 295 45 20 on my old td6.. ... - .- -.
Now are RRS rated for the heavy L322 |
the RRS is heavier than a FF, apparently.. |
just checked ,the FF is 100 kg heavier |
tony66 Member Since: 30 Nov 2014 Location: fife Posts: 92 ![]() ![]() ![]() |
25kg a corner load might sway it for an insurance get out-if you were 5 up with 20stone adults on board,but meanwhile back in the real world i am pretty sure load wise ffrr and rrs wheels should be swappable-or am i wrong? |
It's not 25kg a corner as the RR is not 50/50 yes perdandict but fact
AJS4X4 Member Since: 08 Jun 2012 Location: Surrey Posts: 276 ![]() |
Best to keep load rating of your wheels spot on. |
I agree with recommended for factory tyre size for safety reason alone plus possible insurance hassle. However some tyres are not available in 255/50 R 20 so as Stan says if your going off piste (Cooper etc) try to get the rolling radius as close as possible to factory and never more than about 3% out. |
