![]() | Home > Maintenance & Mods (L322) > strange engine/induction noise |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8347 ![]() ![]() ![]() |
A noise like that is usually caused by something in the wrong place, the engine is isolated from the body of the car to prevent vibration, if some part of the engine is touching the body then it could cause your problems...
J. C. Member Since: 29 Oct 2014 Location: Padova Posts: 38 ![]() ![]() ![]() |
I think that the engine mountings are out of the equation: if they were failed, I should experience noises and vibrations even in neutral, right? As I stated, when in N the engine is noticeably quieter and no vibrations are transmitted through steering wheel or cabin floor.
When put in drive there is a torque effect on the engine and box, if the mounts have failed there is the chance that the small movement in the engine could make it touch somewhere and create the noise...
Hmmm... interesting...
Alright, I spent some time under the bonnet. Put the insulating panel back in plae and checked that nothing is out of place. Still, I get mid-high frequency vibrations through steering wheels, pedal and transmission.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 ![]() ![]() |
you can get the part numbers from the russian online microcat, http://lrparts.ru/engl/ ... - .- -.
Thanks Stan |
