Home > Technical (L322) > lubrication of the blower fan
espaceboy
Hi all,
blower motor has a bit of a squeal this morning.
I there an easy way to get to the blower motor shaft to spray lubricant without removing half the dash?
can you get to the motor shafts by removing the cabin filter panel at the bulkhead?
bit cold outside so looking for a quick way
many thank
Ricky
Post #304172 11th Jan 2015 10:54am
If you strip off the cabin filter housing at the bulkhead you can see a good bit of the blower fan assembly.
I don't doubt you could spray in sufficient oil to stop the thing squealing.
It's what I would try first if I had the problem. Thumbs Up
Post #304203 11th Jan 2015 3:11pm
espaceboy
thanks, will give that a try,
when its warmer!
Post #304204 11th Jan 2015 3:14pm
