Home > Technical (L322) > White smoke |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8285 |
Not good news I'm afraid....
9th Jan 2015 9:30pm |
Bluestu33 Member Since: 31 Dec 2014 Location: Cambridgeshire Posts: 69 |
Thanks Pete, I will get it checked next week.
9th Jan 2015 9:32pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
white smoke is normally down to water , maybe condensation in the exhaust...blue'ish smoke is oil burning. ... - .- -.
9th Jan 2015 10:29pm |
It looks white to me, but I was looking at it through the mirrors. Could the lower than expected mpg be linked? I got 25 today on a steady motorway run |
9th Jan 2015 10:32pm |
25 sounds normal at 70/80 mph...it also all depends how you drive... ... - .- -.
9th Jan 2015 10:34pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8626 |
^ yep 25 ish on a fairly fast motorway run is pretty typical for me too.
9th Jan 2015 11:39pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Are you sure it was 'white' as that would be condensation. Reset your fuel computer on a steady 60/70mph run and you should see about 30-33, this will drop to about 25-27 over urban driving. If it was at night, you are seeing diesel smoke in the headlights of others, check your hoses as pointed out, it's likely one has a small tear/hole. NIce and easy to fix!
10th Jan 2015 12:23am |
Thanks all!
10th Jan 2015 11:56am |
White smoke is unburnt fuel...
10th Jan 2015 2:22pm |
No, only when accelerating hard. Also starts and runs smoothly with no lack of power |
10th Jan 2015 8:47pm |
Easy to check and rule in/out the top hoses they come off with a screwdriver on 5 mins, no special skills required. Have a look in the wiki, there is a how to. |
10th Jan 2015 9:09pm |
The passenger side one comes off easy enough, but getting the replacement one back on ..... you just can't get the leverage easily Drivers side is a doddle though! Land Rover Addict
10th Jan 2015 10:56pm |
Well it's back from the garage and all seems good. They put some cleaner in it to clean the injectors and it seems to have done the trick. |
13th Jan 2015 6:29pm |
nice one ... - .- -.
13th Jan 2015 6:37pm |
