Home > Technical (L322) > headlight washer on 08MY tdv8
rar110
Ive noticed the driver side headlight washer nozzle has dropped into the bumper. Any tips on how this is supposed to be fitted/fixed?
thanks.
Post #301591 29th Dec 2014 1:28pm
rar110
I've done some research on this.
The jets are suppose to sit on top of the bumper and held in place by a steel clip inside the bumper at the top. I will try to access by removing the grill, otherwise it's bumper off.
Post #303777 8th Jan 2015 11:26pm
It would help if you filed in your car profile sir as there are three different jets in the 322 through the ages Thumbs Up
Post #303792 9th Jan 2015 1:00am
rar110
Done
Post #303827 9th Jan 2015 10:50am
They fit onto a plastic square that is welded to the underside of the bumper... I rather suspect the plastic welds have broken due to an impact from the top...
They should not be able to fall through as they are fitted from the top, and if the clip had fell off, they would be trying to escape out the top... Thumbs Up
I suspect you will need to remove the front bumper and bond it back in place with some kind of PU glue...
Quick tip... Check the other side whilst you have it out! Maybe a bad welding job in factory? Maybe worth checking all the parking sensor brackets too (as they are the same) Thumbs Up
Post #303832 9th Jan 2015 11:45am
rar110
Thanks Cam.
I will have to put some time aside to fix it.
I think the plastic on the under side is still in place. It felt like it is and I couldn't manouvre the jet back up through the hole.
The passenger side was ok until I tried to lever the jet cover off. It also fell into the bumper because of my efforts.
Post #304184 11th Jan 2015 12:22pm
Thumbs Up Thumbs Up Thumbs Up
Post #304305 12th Jan 2015 12:05am
