Home > Technical (L322) > My 2006 4,2SC. Whistling and Squealing. YouTube Video.
dhallworth
I read this post before:
http://www.fullfatrr.com/forum/topic19823....eam+valley
I PM'd the OP after I bought my SC just to see what his symptoms were, he advised that it was making a whistling noise and there was carbon on the manifold.
Post #303771 8th Jan 2015 10:08pm
Arkle
I'm hoping it won't take that long! Whistle
I played the YouTube video at the garage and they reckoned it was a pulley for the whistling and a blacked or (I think) split hose for the pan pipes sound.
Post #303788 8th Jan 2015 11:21pm
dhallworth
Be interested to hear what it is in the end Thumbs Up
Hopefully that bank account emptying feature on yours hasn't decided to activate this time!
Post #303791 8th Jan 2015 11:51pm
Arkle
I'm sure there will be some withdrawal symptoms. Laughing
Post #303804 9th Jan 2015 1:24am
dingg1
Arkle - did you get this resolved yet?
Post #306275 19th Jan 2015 11:07am
Arkle
Yet to report back because my car is still in dock. Rolling Eyes
Took it to DSE Macclesfield on Wednesday for a service and investigation in to the noises.
Was called the next day to be told two brake pipes corroded and a couple of rear bushes needed replacing.
Seeing as the car was with them, I also later requested a gearbox oil and filter change.
They had been waiting for parts but the last update I had said the squealing is now gone. It was caused by one of the belts being very shiny! They also re-gassed the air-con because of the belt change?
I'll report back when I get the car back, which I'm hoping will be later today or at some point tomorrow.
Post #306277 19th Jan 2015 11:40am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Definitely s belt noise there after watching the video Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #306282 19th Jan 2015 12:13pm
ebajema
If they changed the multibelt (as opposed to the supercharger belt), I hope they also did the roller/tensioner. The tensioner roller bearing tends to go around the time the belt needs replacing so I do them both (did on the 4.2). The 4.2 also had its supercharger belt replaced. MY 2010 5.0 SC Galway green and sand interior!!
Post #306295 19th Jan 2015 1:31pm
dingg1
Thanks for the update - mine will have to wait till the warmer weather , brrr freezing here,
you do need to drop the aircon charge to remove the fan shroud , Censored design I'd say
Post #306298 19th Jan 2015 1:42pm
Arkle
Thanks, Ebajema.
They changed both belts. Not sure if they replaced the tensioner. Wouldn't cost much so hopefully they changed it!
Just had a call to say they cannot identify the pan pipes noise. May have been cured by changing the belts? They can't seem to get the car to reproduce the noise. Confused
Post #306299 19th Jan 2015 1:47pm
Arkle
The garage said they couldn't get the car to reproduce the pan pipe sound, but here's the latest version of it.
&feature=youtu.be
I hoped it might have been sorted as part of my £1250 bill for servicing and other works. I'll take it back for them to have another listen.
Post #306645 21st Jan 2015 12:50am
ebajema
I listened to it and my 4.2 nor 5.0 didn't have it. I have never heard anything like this before. My suggestion is that it is either in the inlet tract but also could maybe maybe be the cam chain having a tiny bit of slack. MY 2010 5.0 SC Galway green and sand interior!!
Post #306647 21st Jan 2015 4:16am
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
After listening to video 1 no wonder you wanted that sorted ! Shocked
Video 2 much better, pan pipes aside, how nice does a V8 sounds Thumbs Up Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #306657 21st Jan 2015 7:56am
Arkle
A brief update.
Still no further on with sorting out the Pan Pipes.
The stethoscopes have been out and a new crankcase valve was fitted but still the problem (and the air escaping near the O/S front wing under max acceleration) remains.
I'll report back...
Post #313936 20th Feb 2015 2:21pm
