Home > Maintenance & Mods (L322) > Replacing Door Aperture Seal 2005 SC |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
There is at least 4 rubber seals on each door sir
8th Jan 2015 6:26pm |
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110 |
It's the one on the body that goes around the door frame. I think they tend to wear as they get trodden on. |
8th Jan 2015 6:29pm |
Still slightly confused my friend... As you should not be able to tread on it as you have Aluminium tread plates sir |
8th Jan 2015 6:34pm |
8th Jan 2015 6:59pm |
Right... Couldn't remember it sticking out from memory...
8th Jan 2015 9:48pm |
Thank you -'knew it wouldn't be the easiest..... |
8th Jan 2015 9:53pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
How much was the new one please?? my drivers one has seen better days.... Pete
8th Jan 2015 10:01pm |
£48 from Duckworth - Dan's the man |
8th Jan 2015 10:05pm |
Blimey, that's cheap, father in law wanted one for his Toyota Corolla and it was nearly £100...
8th Jan 2015 10:15pm |
Good luck my friend... |
9th Jan 2015 12:09am |
Done! Not as bad as I was expecting. The replacement seal was about 5cm oversize so I had to cut it down. I was worried by this, but I double checked it was fitted fully into the corners all around first. I used a block of wood covered in some rag and tapped it into the awkward spots. Only needed to pull the trim aside apart from the treadplate. The hardest part was getting the treadplate back into position as the clips had moved.
11th Jan 2015 2:23pm |
11th Jan 2015 11:11pm |
Looks much better, why have you got two mats in there??? Pete
12th Jan 2015 9:34am |
You shouldn't have to cut the new seal, are you sure you fitted it tightly into the corners? |
12th Jan 2015 10:48am |
