Home > Technical (L322) > Rattle from rear axle
Stormin
2003 Range Rover HSE Td6 Epsom Green
Driving home this morning and the pig sounded terrible, a rattling noise coming from the rear end.
At first I thought it was the brake back plates as it sounded similar to when the front ones rusted loose. But no they seem tight.
Checked all other heat shields in case one had become loose and was dragging on the propshaft, looked Ok.
My Indy is off sick at the mo. so taken to another garage, who think that it sounds like either the pads or handbrake shoes have broken up.
Is this normal ???
or any other suggestions please Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #303484 7th Jan 2015 7:47pm
If they are the original handbrake shoes then yes it's possible that maybe a spring has broken or similar..... There is nothing that can't be fixed with a hammer😜😜
Post #303494 7th Jan 2015 8:17pm
Possible that the shoe holding pins have "pulled" through their holes in the back plate and these are rattling around?
If dismantling try to release the pins from the outside, otherwise they are likely to pull though the back plate when you jemmy the brake drum off! .
Post #303497 7th Jan 2015 8:24pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
How long since the roller pins/bushes were done? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #303524 7th Jan 2015 9:43pm
Stormin
Got her back and as you all correct diagnosed it was the hand brake shoes that had disintegrated and the pins dropping out.
She's back all quiet.
Thanks Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #303724 8th Jan 2015 8:07pm
Thumbs Up .
Post #304023 10th Jan 2015 10:34am
Post #304033 10th Jan 2015 10:55am
