Home > Technical (L322) > My 2006 4,2SC. Whistling and Squealing. YouTube Video.
Arkle
Mornin' all.
I may have mentioned in the past about my 4.2SC Whistling and or Squealing.
When I bough the car, the seller said that the garage he bought from "Bent the air pipe" when servicing before releasing the car to him.
It runs okay, and the pan pipes sound disappears after a couple of miles but the squealing (used to abate after a 5 mile run) now remains at all times.
I have uploaded a video to YouTube, See link below.
I made the video at night with the windows down to maximise the sound quality.
Any ideas please?
TIA.
Paul.
&feature=youtu.be
Post #303259 7th Jan 2015 3:26am
i reckon belt tensioners and alternator...(only a guess mind) ... - .- -.
Post #303271 7th Jan 2015 8:33am
dingg1
Water pump on its way out??
Post #303273 7th Jan 2015 8:36am
Arkle
Thanks for the replies.
My first thought for the squealing was water pump bearing but I have no idea what the pan pipes thing is all about.
Any further ideas please chaps?
Post #303295 7th Jan 2015 9:24am
your car profile is missing so i assume you have a 4.2 so here's the bits that are at the front that might be making the noise,
Post #303296 7th Jan 2015 9:32am
Arkle
Thanks for that, Stan. I'll take a look later today. Thumbs Up
Post #303300 7th Jan 2015 9:37am
pld118
Sounds unhealthy and not a noise I've heard from ours. Interested to find out what it is.
Post #303308 7th Jan 2015 10:13am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Can't hear it whilst I am at work, but mine has a whining noise which I am convinced is the alternator. Local dealer says not done many/any alternators on a 4.2! turning on all the lights, heated screens and heater made the noise a lot worse and then almost goes when everything is turned off again.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #303325 7th Jan 2015 10:49am
dingg1
I have a similar squeel on mine on first starting up , I've come to the conclusion the water pump is on its way out , pump arrived today , does anyone know if its much of a job on the 4.2 s/c or is it a simple whip off and on (I doubt it looking at access Laughing )
any online tutorial anywhere??
cheers
Post #303664 8th Jan 2015 5:03pm
petrol 4.4 here which cant be that different to the 4.2,
http://www.fullfatrr.com/forum/topic16423.html ... - .- -.
Post #303670 8th Jan 2015 5:39pm
Arkle
Mine is booked in at DSE LR Services on Wednesday. I'll report back.
Post #303671 8th Jan 2015 5:40pm
dingg1
quite different to the 4.4 Stan, looks as if shroud needs to come out which also looks as if aircon refrigerant needs to be dumped , if my mechanic doesn't take it on (mot place who does minor works) looks like a job for the summer to me Confused
probably easier to take the grill and top slam panel off and retrieve the full rad pack and attack it from there , now is there anything else I should do when I'm in there?
wish I'd changed it out a year ago when I rebuilt the damn thing Big Cry
Post #303683 8th Jan 2015 6:25pm
ah ok.. Thumbs Up ... - .- -.
Post #303706 8th Jan 2015 7:19pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
My 4.2 S/C also has a slight "chuffing" noise when it is cold, which eases off when it gets warm.
Nothing like as loud as yours and does not have the whistling, but I will watch this thread with interest... 4.2 Supercharged Vogue SE
Post #303729 8th Jan 2015 8:19pm
Arkle
The squeaking is made worse by moist conditions. It was hardly noticeable in the warmer months and would soon abate but the winter weather has seen it worsen and stay even after a good 10 mile run, so in she goes for fear something gives way.
The pan pipes is possibly a bent pipe or perhaps a blockage with berries from my neighbours tree, Whistle
Post #303749 8th Jan 2015 9:25pm
