![]() | Home > Maintenance & Mods (L322) > Rear Led Tail light conversion wiring thought |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I have a broken rear light |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
i think its more complicated than that and these resisters do get hot if left on for a while...afaik there's a constant live which is switched by impulses from the ecu when each light is required...
Yes I was looking at the clear super changed one's, but I'd probably break them too |
craig does a lot of conversions and he might be able to give some expert thoughts on the 'adapters' for the 2010/12 led lights.. ... - .- -.
Are but that will cost me £650 fitted |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Sorry Stan, we haven't, don't and won't fit resistor kits ![]() |
So from that I can assume that you've some way of reprogramming on the board monitoring system, and what sort of damage would we be talking if I were to fit the lights and you make 'em work |
Rear light prices are on the website sir |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
scored a set of 2012 tails for $525 shipped. Looking forward to the update this weekend |
Having read lots of posts about light fitting, and different voltages, I have decided to go the Supercharged route. Mainly because I know that a FFRR is sensitive about electrical changes, and I wouldn't want to upset the apple cart, so to speak |
Just a thought, do you think it's wise to employ some epoxy resin and go over all the seams before fitting them, or should I take a chance that I've got the only fully sealed set to come from the factory ? |
