Home > Maintenance & Mods (L322) > 100% engine coolant flush - special tip?
verydisco
Hi gang
On the 2002 4.4L V8 G4, for preventive measures, we are replacing, amongst many other things, all the engine coolant pipes (engine and heater system). Engine ones already fitted. heater system pipes on order
By definition, the engine is now empty of fluid. Before we fill it up again, is there any special tip to know or is it just, check all pipes and clips, fill up and start her up - then double check levels ?
Cheers l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #302867 5th Jan 2015 3:34pm
Don't know, but I wouldn't leave it empty too long. There is nothing that can't be fixed with a hammer😜😜
Post #302891 5th Jan 2015 6:24pm
Don't think you can get all the coolant out of the engine, there will be a fare amount sat in the bottom of the waterways, maybe worth flushing and back flushing the engine to try to get all the old stuff out....
There again I don't think it would make much difference....
When you refill it just do it nice and slowly to let the air out, seems to fill better, with less airlock problems, if you use a 50/50 mix to fill it rather than putting the thick antifreeze in first, then water on top.... Pete
-Click here for Thread-
Post #302911 5th Jan 2015 7:16pm
verydisco
Thanks
Flushed it 3000 Km ago before that but indeed might be worth thrying to get any gunk out.
thanks Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #302941 5th Jan 2015 8:53pm
verydisco
Done!
Coolant, all hoses, plugs, thermostat, etc. Thumbs Up
good for another decade Whistle
Current
Previous:
Post #306476 20th Jan 2015 12:26pm
